Dustin_V
Apr 07, 2020NETGEAR Employee Retired
New Feature: Unblock URLs with NETGEAR Armor
NETGEAR Armor’s latest feature puts you in control by allowing you to unblock URLs. While NETGEAR Armor automatically blocks suspicious and potentially dangerous websites, if you believe that a w...
Kscelfo
Apr 12, 2020Initiate
This feature needs to allow the typing in of URLs. It is tremendously annoying to have to unblock every variation of a URL from shorteners like amzn.to
- Christian_RApr 15, 2020NETGEAR Employee Retired
Hi unwdre,
Thanks for confirming. May you try rebooting the router and reinstalling the app. Let me know if there are any improvements.
Thanks,
Christian
- unwdreApr 15, 2020GuideReinstall? Meaning disable and re-enable?
- Christian_RApr 16, 2020NETGEAR Employee Retired
Hi unwdre,
Thanks for getting back. I'd like for support to look into this further. If you wish to be contacted, please send me a private message with your contact info.
Thanks,
Christian
- unwdreApr 17, 2020Guide
Spoke with Level 2. They were no help. Suggested I submit the website to Bitdefender to review which doesn't address the issue and not a functional solution. Will be disabling it until it actually functions correctly.
