RykGroff
Jan 07, 2025Aspirant
Nighthawk Blocking Malicious Sites but What Are They?
Recently got a Netgear router and downloaded Nighthawk as instructed. It tells me often that it's blocked a malicious site, but I don't see any place I can go for it to actually TELL me what those si...
Jan 09, 2025Guru - Experienced User
Is it causing issues?
RykGroff
Jan 12, 2025Aspirant
When I search Support here and ask how to see the URLs Armor is blocking, it says:
To Unblock Websites in NETGEAR Armor:
- Launch the Nighthawk or Orbi app from a mobile device that is connected to your router’s network
- Tap Security - The NETGEAR Armor dashboard displays
- Tap Threats Blocked - A list of suspicious URLs NETGEAR blocked displays
- Tap on the URL that you want to whitelist
- Tap Add to Unblocked - A warning displays
- Tap OK
This is not true. All I ever get after clicking "Learn More" is "Malicious_host" and "OK".
This is NOT helpful AT ALL!
(Nighthawk ver. 2.42.1.4373 on Android 14)
