dlxxxc
May 07, 2023Aspirant
Nighthawk r7000
I am looking for the Armor client for Mac OS to run on my MacBook Air. Can't seem to find the download, no URLs etc.
Is there a client for Armor to run on MacOS
Device specific downloads usually appear in the support pages for that model:
Visit the support pages:
Support | NETGEAR
That page should have any software, firmware and drivers for your device, if they exist.
Also try asking here:NETGEAR Armor - NETGEAR Communities
- dlxxxcAspirantThat's the first place I looked at of course. Very unclear and only android and ios is shown as supported
- dlxxxcAspirantThe support site is rubbish. Even the firmware versions are not downloadable. Getting messages file not found for every single firmware upgrade. And av software is only mentioned fot ios and android
dlxxxc wrote:
Even the firmware versions are not downloadable.They work just fine here.
R7000 Firmware Version 1.0.11.136 | Answer | NETGEAR Support
Getting messages file not found for every single firmware upgrade.Something is amiss at your end. Hard to tell with no details about what you are using to download these files.
And av software is only mentioned fot ios and androidThat's because, as explained, Netgear doesn't produce "av" software for particular models.
Support for stuff like Armor and parental controls is at the firmware level. A lot of the management then happens through an "app" for your mobile devices.
You seem to be a bit confused as to how Armor works. I see no sign that you have posted a question in the most appropriate place to get help with that:
Then there is this:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
