semisouthpaw
Sep 30, 2021Initiate
Not sure how to unblock sites. R7000 is blocking every site except netgear.com
Hi, I'm not sure what the problem is. My Netgear router and modem were working just fine until I switched internet provider accounts, then my router stopped working. I reset both my router and mo...
Sep 30, 2021Guru - Experienced User
what modem/gateway is the r7000 connected to?
What firmware is on the router?
semisouthpaw
Oct 03, 2021Initiate
Problem solved: I needed to register my router again. Thanks for trying to help!
- plemansOct 03, 2021Guru - Experienced User
Didn't help but glad you got it fixed!
