smoddelm
Mar 31, 2023Tutor
Obri RBK850 - Armor "Exception from Onecloud"
This morning when I logged onto the Orbi android app, I immediately noticed in the security block where the status of Armor is indicated that it said in red letters "Protect with Armor Now." I have ...
Mar 31, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I would submit a bug report:
ashred13
Mar 31, 2023Aspirant
I rebooted the router multiple times from the Orbi app itself and it did nothing.
I was getting to the point where I was going to try a Factory reset of the Orbi router because a help page indicates that you will have to manually set up the Armor and Parental Controls again. So I thought maybe turning off the security protections might get it to work again. I turn off my wifi at night due to a sneaky child and I can't turn it back on because of this error message.
- FURRYe38Mar 31, 2023Guru - Experienced User
Turn on computers and rest of network.Please hold off on doing any Factory Reset for now.
