smoddelm
Mar 31, 2023Tutor
Obri RBK850 - Armor "Exception from Onecloud"
This morning when I logged onto the Orbi android app, I immediately noticed in the security block where the status of Armor is indicated that it said in red letters "Protect with Armor Now." I have ...
ashred13
Mar 31, 2023Aspirant
I rebooted the router multiple times from the Orbi app itself and it did nothing.
I was getting to the point where I was going to try a Factory reset of the Orbi router because a help page indicates that you will have to manually set up the Armor and Parental Controls again. So I thought maybe turning off the security protections might get it to work again. I turn off my wifi at night due to a sneaky child and I can't turn it back on because of this error message.
Mar 31, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Please hold off on doing any Factory Reset for now.
