smoddelm
Mar 31, 2023Tutor
Obri RBK850 - Armor "Exception from Onecloud"
This morning when I logged onto the Orbi android app, I immediately noticed in the security block where the status of Armor is indicated that it said in red letters "Protect with Armor Now." I have ...
Chuck-IV
Mar 31, 2023Guide
Getting the same error. The security portion says it's not activated and when trying to go into it, it gives the "Exception from OneCloud"
I'm guessing either a OneCloud issue directly or the new app update(at least for iOS, got one yesterday) screwed up the linking,
- FURRYe38Mar 31, 2023Guru - Experienced User
Yes, noticed this as well.
I've passed this onto NG for review.
Please be patient.
- smoddelmMar 31, 2023TutorI tried the modem / router reboot sequence that was suggested and it didn't fix the problem. Seeing that others are having the same issue and have reported it, I will wait for now.
Thanks for letting us know.
Hopefully NG can get this fixed soon.
- Hannah123Mar 31, 2023InitiateMine is same thing
