smoddelm
Mar 31, 2023Tutor
Obri RBK850 - Armor "Exception from Onecloud"
This morning when I logged onto the Orbi android app, I immediately noticed in the security block where the status of Armor is indicated that it said in red letters "Protect with Armor Now." I have ...
Mar 31, 2023Guru - Experienced User
Yes, noticed this as well.
I've passed this onto NG for review.
Please be patient.
smoddelm
Mar 31, 2023Tutor
I tried the modem / router reboot sequence that was suggested and it didn't fix the problem. Seeing that others are having the same issue and have reported it, I will wait for now.
- FURRYe38Mar 31, 2023Guru - Experienced User
Thanks for letting us know.
Hopefully NG can get this fixed soon.
- Chuck-IVMar 31, 2023Guide
Seems to be working now, but now of course, the app goes back to the broken mess that it was with it showing devices offline when they are online and such. When this was broken, I had a nice blue page showing what devices were connected to 2.4, 5g and wired, grouped separately and it showed each connected device that was online. Now it's back to that one conglomerated list that is wrong. Wish I could get back that blue separated view.
- BK1959Mar 31, 2023Star
Perhaps this bug was caused by the latest update of the Orbi app? It looks as if they went back to the status it had before the update.
