TheGrumpyGent
Dec 14, 2021Tutor
Old Bitdefender Version???
Hi, I have a recently purchased Netgear Orbi AX6000, it’s setup and I have Netgear Armor. I’ve installed Bitdefender Total Security on several devices, and I’ve found out that the version is actually ...
kiyuu
Jul 06, 2022Star
The parental control with Orbi is called Circle and you have to install a separate app for it. The basic service is free but if you want more options you have to buy a premium subscription, just as with the Bitdefender VPN. I agree, though, that it's better to get anti-virus/security software directly from the source rather than through Bitdefender Armor. I am completely unhappy with the way things have turned out with the Bitdefender software provided through Netgear Armor.
John_Ba
Sep 03, 2022Luminary
The program and the VPN one are now months behind Bitdefender updates. Indeed both are a full version never than the Netgear versions and piling on updates which I can only think are pushing security gap updates.
