JQuijano
Jan 04, 2023Tutor
Orbi 960 Crashes During High Speed Downloads Over Ethernet
I have the exact same issue, if i'm downloading and speeds reach over 800mbps, my Orbi RBRE960 restarts every single time. It doesn't matter what game client I use, Steam, Blizzard, etc.
Contac...
Jan 05, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Do you have Armor, SPC or traffic meter enabled?
I've not seen this on my 9 series...
Contacted support and was walked through the exact same nonesense, the problem persist.
I was previously using an Asus Rog Rapture GT-AX11000, never experience this problem.
