epsom11
Oct 29, 2019Tutor
Orbi and Netgear Armor - cannot activate
Hello I have an Orbi setup (1 router + 2 satellites). I purchased the Netgear Armor subscription from Bitdefender. I got the approval and the activation code. If I login to armor.netgear.com, I ca...
- Sep 09, 2020
Netgear support had me hold the reset button for 15 seconds and then reconfigure the Netgear router as if it was new. I had a few issues working through the reconfiguration. It may have helped if I had thought to unplug the satellites before doing the reset. In any event, it worked. After reconfiguration the security software was activated in the app.
Alev
Mar 27, 2020Aspirant
Same here...after the trial expired, I bought Armor from the NETGEAR website on my Mac. Got the email, activation code; activated, but my Orbi app says it’s expired and takes to me the purchase page. Please help?
mkfein
Mar 29, 2020Star
I have the same issue... bought the subscription on armor.netgear.com, which shows my subscription is active.
But, I can't seem to get my Orbi to realize that. The app and web interface both show inactive with no apparent way to update...
Frustrated...
