epsom11
Oct 29, 2019Tutor
Orbi and Netgear Armor - cannot activate
Hello I have an Orbi setup (1 router + 2 satellites). I purchased the Netgear Armor subscription from Bitdefender. I got the approval and the activation code. If I login to armor.netgear.com, I ca...
- Sep 09, 2020
Netgear support had me hold the reset button for 15 seconds and then reconfigure the Netgear router as if it was new. I had a few issues working through the reconfiguration. It may have helped if I had thought to unplug the satellites before doing the reset. In any event, it worked. After reconfiguration the security software was activated in the app.
mcs_01
May 28, 2020Initiate
Same issue. Security ‘expired’ stuck on purchase page despite subscription. Account activated but ‘expired’ nonetheless. Infuriating. Feeling scammed.
Christian_R
May 29, 2020NETGEAR Employee Retired
Hi mcs_01,
May you let us know how you purchased the subscription (Orbi app, Bitdefender website, etc)?
Thanks,
Christian
- nzteddy2020Jun 03, 2020Aspirant
I had the same problem. However my experience with netgear support has been great. I used the chat function on the Orbi app to connect directly with Live chat. Theresa worked with me for ages to sort it out. In the end I needed to update the firmware on the router manually, the satelite had updated online but not the router. this seemed to sort it all out.
