epsom11
Oct 29, 2019Tutor
Orbi and Netgear Armor - cannot activate
Hello I have an Orbi setup (1 router + 2 satellites). I purchased the Netgear Armor subscription from Bitdefender. I got the approval and the activation code. If I login to armor.netgear.com, I ca...
- Sep 09, 2020
Netgear support had me hold the reset button for 15 seconds and then reconfigure the Netgear router as if it was new. I had a few issues working through the reconfiguration. It may have helped if I had thought to unplug the satellites before doing the reset. In any event, it worked. After reconfiguration the security software was activated in the app.
dennismclyde
Sep 09, 2020Tutor
relberfeld
Sep 09, 2020Apprentice
how does it work ? does it slow anything down ? is the software already on the router or is it downloaded ?
