kcor
Dec 15, 2019Aspirant
Orbi Armor impacting xbox speeds and Packet Loss
Hello all, Have an xbox One hard wired into a switch. Switch is connected to Orbi then to cable modem acting as a bridge. Before these issues, I consistently received speeds of 350ms down and 25...
- Dec 15, 2019
Hi kcor, does disabling the Armor feature get your speeds back up to how it was? The link below are the steps i disabling it.
Dexter
Dec 15, 2019Guru - Experienced User
Factory reset the RBR and this time setup from scratch and do not enable Armor. Check speeds.
Others have posted various issues using Armor. Would not be good for gaming.
