kcor
Dec 15, 2019Aspirant
Orbi Armor impacting xbox speeds and Packet Loss
Hello all, Have an xbox One hard wired into a switch. Switch is connected to Orbi then to cable modem acting as a bridge. Before these issues, I consistently received speeds of 350ms down and 25...
- Dec 15, 2019
Hi kcor, does disabling the Armor feature get your speeds back up to how it was? The link below are the steps i disabling it.
Dexter
DexterJB
Dec 15, 2019NETGEAR Moderator
Dexter
kcor
Dec 17, 2019Aspirant
I was able to hard reset the orbi and my speeds are back to nornal. Thank you! However, I am still having packet loss issues on the xbox. Latency is running at about 62-67ms which is good but a lil higher than friends I have asked to test their xbox speeds. After the hard reset I am still running a 1-3% packet loss.
I will have to reach back to Netgar/ Bitdefender for a possible refund on the Armor product if this is not going to work.
Thanks again for the help and any additional guidance will be apreciated.
