kcor
Dec 15, 2019Aspirant
Orbi Armor impacting xbox speeds and Packet Loss
Hello all, Have an xbox One hard wired into a switch. Switch is connected to Orbi then to cable modem acting as a bridge. Before these issues, I consistently received speeds of 350ms down and 25...
- Dec 15, 2019
Hi kcor, does disabling the Armor feature get your speeds back up to how it was? The link below are the steps i disabling it.
Dexter
DexterJB
Dec 15, 2019NETGEAR Moderator
Dexter
DexterJB
Dec 18, 2019NETGEAR Moderator
Hi kcor, thanks for responding. Do you still have Armor enabled? If yes, as a way to isolate what's causing the issue, please try temporarily disabling it and check if there is any improvement on the latency (ping). If the issue will persist while Armor is disabled, you can try and check the modem. You can bypass the router and connect straight to your ISP's modem and check if it is still the same.
Dexter
- kcorDec 18, 2019Aspirant
Armor is disabled. I am going to go straight to the ISP modem and let you know how that works out. First, I have to hard reset that device again as I have it setup as a bridge. Will reach back shortly. Thank you again for all the guidance!
- kcorDec 19, 2019Aspirant
Ok, I went ahead and hard reset the ISP modem and ran some tests. Was still getting 1-3% packet loss. I reached out to ISP and they were looking into. Woke up this AM and ran about 20 tests and only 1 test had a .34% packet loss. So I am thinking I am all set now as chalking up the packet loss as a ISP issue. Thank you for the help.
