jamesjwd
Apr 24, 2024Aspirant
Orbi blocking some Chase Bank Website Functions?
I just got the Orbi AXE11000 Wi-Fi mesh sytem (Router with 2 Satellites) for our office network. However, it seems that it is blocking functions of some websites. Like Chase Bank Website. We...
Apr 24, 2024Guru - Experienced User
Have you enabled Armor on the system? Can be disable thru the Orbi app under Security from left side menu.
This happen across multiple devices for same site?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
