Khanghura71
Feb 24, 2021Aspirant
Orbi LBR20 Armor Activation
Hi all Hopefully someone can point me to right solution. I have an Orbi LBR20 4G/LTE Router which I needed to reboot after connecting the Poynting XPOL-1 v2 and doing a firmware update. Which ha...
Khanghura71
Feb 25, 2021Aspirant
Hi Christian
Is that a hard reset of the router or simply unplugging the unit for about 30 seconds and then replugging.
Also I have the Orbi App on several devices am I required to delete on all devices and re-install?
Thanks
Christian_R
Feb 25, 2021NETGEAR Employee Retired
Hi Khanghura71,
Unplugging and replugging the unit. And yes, you may reinstall the Orbi app on all devices.
Christian
- Khanghura71Feb 27, 2021AspirantHi Christian
Took the steps you mentioned and still no joy.
Can you advise on a solution?
Kind regards.- Christian_RMar 01, 2021NETGEAR Employee Retired
Hi Khanghura71,
Thanks for the update. May you send me a private message and confirm your email address and router serial number for us to check further.
Thanks,Christian
