Duarditoh85
Feb 16, 2020Aspirant
Orbi limiting Raspberry Pi Bandwidth
Hi! Im experiencing a really weird issue with my Orbi system. I have latest firmware on my router and satellites (2.5.1.8). My following installation looks like that: - Nokia fiber modem -> Orbi RB...
Duarditoh85
It could be a possibility... But i always used the same speedtest plugin in Kodi. And i get full speed from my provider (Around 500Mb) Just when i dont use the Orbi. So... Im pretty sure that something is going on the re...
CrimpOn
Feb 16, 2020Guru - Experienced User
I did more tests on speedtest.net and notice that my Pi 4B starts out at "full speed" for about 10 seconds (above the 200mbs I pay for), and then the speed falls off sharply and ends up quite a bit less, but still in the neighborhood of 100mbs. My Windows computer does not exhibit this phenomenon. It stays at a pretty constant rate throughout the test. Android phone & tablet the same.
I struggle to comprehend how the Pi could be treated "differently" by the Orbi from Windows and Android devices. The Pi does respond to heat by dropping the clock rate. I am not confident how to measure for that effect while doing a speed test.
I did install Kodi, but "nothing happened" when I started it from the graphic desktop. Maybe it senses there is no HDMI connection on my "headless" Pi?
There are numerous posts on the forum questioning the Orbi's ability to deliver "full speed". Orbi was submitted to the FCC back in 2016, when 100mb speeds were rare, and I do not remember anyone offering gigabit to residential customers. Perhaps another test is to connect a computer to the switch and test speed with it. Does it achieve higher speed than the Pi? (Mine did.)
Sorry not to be much help.
- Duarditoh85Feb 16, 2020AspirantWhen i use a computer connected to the switch i get Around 500/500. The only way to get Around 500 is to connect the Pi directly to the Nokia modem. If it goes directly to the Rbr50, i get Around 40Mb. Thats a big difference. Same cable used for both tests.
- CrimpOnFeb 16, 2020Guru - Experienced User
Thanks for doing the test. I am puzzled about the 40mb results. My Pi 4B gets over 100 with Firefox and almost 100 with Chromium.
Amazon says 15mb will stream 4K video. Netflix wants 25mb. Both are a lot less than 40mb.
It could be there are two issues:
- Why does Kodi buffer on the Pi?
- Why does the Pi get so much less "speed" when connected to the Orbi?
I think the problem is some QoS hidden features on the Orbi system. Ill try to switch off the two satellites and try again to see if a get another result.
I get buffer issues just sometimes, but when it happened, it does every 5 seconds...
I had another "weird" issue that was isolated. I got my IPTV decoder (From my ISP) to freeze every 2-3 minutes. Problem was on one of my computers ethernet card and "Wake on lan". It must be disabled to get my IPTV box working as normal.
So... this is the second weird problem with my Orbi system and sure i need to do again a step-by-step connecting just the Pi and one by one the other devices.
Ill try when i arrive at home today :)
Found a way to observe Pi cpu speed, and looks like that is "not it."
watch -n 5 vcgencmd measure_temp
where n is the number of seconds between observations. (I used 2). My Pi was at 49c when idle and "climbed" to 52c doing speedtest.net (55c for Firefox). The Pi 4B does not throttle clock speed until the CPU temperature goes over 70c. I cannot measure GPU temperature since my Pi is "headless".
