Gudel2
Apr 13, 2019Apprentice
Orbi RBK50
How do i put back a device that was on my network for armor to access for threats and other security stuff. I made a mistake by removing the device from my network. I removed the wrong device.
Apr 13, 2019Guru - Experienced User
Please post about this in the Armor forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Good Luck.
Gudel2
Thanks I moved it
- Orbi-RocJun 15, 2019Luminary
Hi Gudel2 . This is an old post, so presumably you already got this sorted out. I think all you have to do in such instances is to key in the password when using that device to connect to your network and it will be fine thereafter. If you blocked the device from the router Web page, you can simply unblock it.
