quidneck's avatar
quidneck
Orbi RBR50 - Armor BitDefender installation on Mac
Hi  I have an Orbi mesh router and am trying to install Netgear armor Bitdefender on my Mac. After the application successfully installs on the Mac I am requested to log in using my Netgear user id/p...
  • DexterJB's avatar
    Dec 09, 2019
    Hi quidneck, welcome to the community! Are you able to login using the same credentials on armor.netgear.com? Did you use the link provided via the Armor app/UI?
    Dexter
