quidneck
Dec 07, 2019Aspirant
Orbi RBR50 - Armor BitDefender installation on Mac
Hi I have an Orbi mesh router and am trying to install Netgear armor Bitdefender on my Mac. After the application successfully installs on the Mac I am requested to log in using my Netgear user id/p...
DexterJB
Dec 09, 2019NETGEAR Moderator
Hi quidneck, welcome to the community! Are you able to login using the same credentials on armor.netgear.com? Did you use the link provided via the Armor app/UI?
Dexter
quidneck
Dec 09, 2019Aspirant
Hi Dexter,
Thankyou. It worked when I used the link on armor.netware.com. It didn't work when I initiated the install using the Orbi app on an IPhone.
