ZoneMaster
Jun 21, 2019Apprentice
ORBI RBR50 Fails to Accept Armor Subscription
I purchased & activated a subscription to NETGEAR Armor on the last day of my free trial (June 20th): The subscription pane of the Armor website showed that my macOS, Windows, & Android AV apps acc...
- Jul 21, 2019
Email bdsupport@tickets.bitdefender.com or go to the main Bitdefender support site http://www.bitdefender.com/support.
Clearly explain your situation. For example:
I purchased & activated a subscription to NETGEAR Armor:
1. The subscription pane of the Armor website showed that my macOS, Windows, &; Android AV apps accepted the new subscription.
2. The ORBI router still showed as active on the trial.
When the trial expired, the router failed to recognize the new subscription (see attached). The Armor icon in the ORBI iOS app status was Expired.YOU MUST INCLUDE YOUR LICENSE KEY! That is how Bitdefender will identify your account. Your account will be fixed in a few days.
YvaMa
Aug 12, 2019Tutor
Hello,
Finally it took a little patience because, after 10 days of exchanges with Bitdefender, the synchronization problem was remotely set by the support. Do not hesitate to call on Bitdefender support if this happens to you, a few small worries from the beginning ...
DexterJB
Aug 12, 2019NETGEAR Moderator
Hi YvaMa, thank you for the update and glad to know they were able to sort it out for you! For reference, you can reach Bitdefender on the link below.
https://www.bitdefender.com/consumer/support/
Dexter
