dwax
Jul 14, 2021Guide
Orbi RBR850 crashes with large downloads
My kids and thier gaming require large downloads from battle.net and Epic games. These downloads are often greater than 100GB. When they start to download the router RBR850 loses its connection t...
- Aug 29, 2022
My Orbi 750 is running Firmware Version V4.6.8.2_2.1.9. Support suggested turning off Armor and that stopped the crashing. Awaiting a real resolution since paying for Armor but having to have it disabled for a game to download from Steam shouldn't be the solution.
Jul 14, 2021Guru - Experienced User
Is Armor or IPv6 enabled on the RBR?
Check the LAN cable in between the RBR and CM modem. CAT6 is recommended.
Is the game consoles wire connected to the RBR? or wireless connected?
How many devices do you have online when the downloads are happening?
dwax
Jul 14, 2021Guide
Thanks for the reply!
Firmware V3.2.18.1_1.4.14
No Armor or IP6
Brand new short cat6 cable
I’ve tried the game PCs wired, 5ghz, and 2.4ghz. Downloads start at 30-40MB/s and slowly slow down and then the router is inaccessible
We have about 15-20 devices on the net doorbell, thermostats, PCs, voip phone, multiple Amazon echoes
No Armor or IP6
- FURRYe38Jul 14, 2021Guru - Experienced User
Is Link Aggregation enabled on the CM modem? It should be disabled.
Someting to try at a later date if you have a spare LAN cable, enable LAG on the modem and RBR. See if this changes anything.Something to try as well, if you can, Power OFF the modem and RBR. Connect the game device to the back of the CM modem where the RBR is connected too. Disconnect the RBR. Power ON the modem and game device. Download something check it's operation...
- dwaxJul 16, 2021Guide
So we bypassed the RBR and the 110GB file downloaded without issue. This definately an ORBI RBR850 issue
Is there a phone number that I can call to get Netgear to try and reproduce this? Do they monitor this community?
So I could try ORBI> WAN aggregation (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad)
CM1200> Enable (LACP-IEEE 802.3ad) (Port 1 & 2)
I assume I will lose a switch port on the ORBI to amke this happen?
You would think that a port "capable of handling 2.5GBPS" should nto choke and crash the router.. Its behaving like a failing router to a denial of service attack.... These downloads are only hitting 35MB/s
- FURRYe38Jul 16, 2021Guru - Experienced User
dwax wrote:So we bypassed the RBR and the 110GB file downloaded without issue. This definately an ORBI RBR850 issue
Good to know. CM modem is working.
Where or what files are you downloading when this happens? Is this a specific site or something on the game device?
CM1200> Enable (LACP-IEEE 802.3ad) (Port 1 & 2) Yes, Enable LAG on both RBR and CM modem. After you enable these and apply, reboot both CM and RBR and while they reboot, connect up both LAN cables. Then try the download again.
No, All other LAN ports are working on the RBR. You may need a additional LAN GB switch if you think you may run out of LAN ports on the RBR. You can use a LAN switch connected to the back of the RBR for additional LAN ports.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Possible something in handling of these files thru the RBR and the one device maybe causing problems. May need to see if we can capture debug logs from router IP address/debug.htm. I had my two game consoles connected to my RBR850 series and have downloaded many updates and games accross the RBR and my CM1200. Haven't seen this...
Might wanna get you some beta FW to test as well. There is beta available that I'm running...
