dwax
Jul 14, 2021Guide
Orbi RBR850 crashes with large downloads
My kids and thier gaming require large downloads from battle.net and Epic games. These downloads are often greater than 100GB. When they start to download the router RBR850 loses its connection t...
- Aug 29, 2022
My Orbi 750 is running Firmware Version V4.6.8.2_2.1.9. Support suggested turning off Armor and that stopped the crashing. Awaiting a real resolution since paying for Armor but having to have it disabled for a game to download from Steam shouldn't be the solution.
SQUIDWARD360
Jul 17, 2021Guide
Same issue here. RBR750 v4. 6.3.7 CM1200. I thought it was an issue with a device that was connected. The Orbi would go solid purple and my wired and wireless connections would drop. A reboot of the Orbi would fix it for a few minutes. Eventually I would have no issue and it was unexplained. It wasn't until I attempted to download the Cold War 87GB patch on an additional wired PC and the Orvi went solid purple again that I realized it was the download crashing the Orbi. I had been downloading the patch on another wired PC earlier in the day when the issues were first occurring. I've never had this happen during any other download.
- FURRYe38Jul 17, 2021Guru - Experienced User
Thanks for helping to check this. I recommend both you and dwax open support tickets with NG support as soon as possible.
I'll try and pass this on to NG as well.
- SQUIDWARD360Jul 18, 2021GuideI opened ticket 44839819.
- FURRYe38Jul 18, 2021Guru - Experienced User
I'm doing a 18Gb new installation of Diablo 3 on my wired Windows 10x PC connected to the RBR850 w v223 beta loaded.
I installed the battlenet app first then logged into my account. Found that D3 wasn't installed but I can download it since I have the original install DVD as well. Downloading currently at over 200Mpbs.
I'll report back results...
- mattcieslewiczAug 25, 2022Aspirant
has there been any resolution to this crashing issue? Also have the 750 and never had an issue with download crashing previous routers. Also have issues with just devices working when they are connected (ie. laptop and phone are both connected to the orbi wifi, but when trying to load an email or website it just spins until you disconnect from wifi and reconnect).
- jparrishAug 25, 2022TutorMine seemed to fix itself with a firmware update. I paused all big downloads for a long time and then happened to boot steam up after a restart without really thinking and had multiple games update at fast speeds with no issue. Sorry I can’t be of any more help.
- FURRYe38Aug 26, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How big are these downloads in size?
- mattcieslewiczAug 29, 2022Aspirant
