dwax
Jul 14, 2021Guide
Orbi RBR850 crashes with large downloads
My kids and thier gaming require large downloads from battle.net and Epic games. These downloads are often greater than 100GB. When they start to download the router RBR850 loses its connection t...
- Aug 29, 2022
My Orbi 750 is running Firmware Version V4.6.8.2_2.1.9. Support suggested turning off Armor and that stopped the crashing. Awaiting a real resolution since paying for Armor but having to have it disabled for a game to download from Steam shouldn't be the solution.
Jul 17, 2021Guru - Experienced User
Thanks for helping to check this. I recommend both you and dwax open support tickets with NG support as soon as possible.
I'll try and pass this on to NG as well.
SQUIDWARD360
Jul 18, 2021Guide
I opened ticket 44839819.
- FURRYe38Jul 18, 2021Guru - Experienced User
I'm doing a 18Gb new installation of Diablo 3 on my wired Windows 10x PC connected to the RBR850 w v223 beta loaded.
I installed the battlenet app first then logged into my account. Found that D3 wasn't installed but I can download it since I have the original install DVD as well. Downloading currently at over 200Mpbs.
I'll report back results...
- FURRYe38Jul 19, 2021Guru - Experienced User
NO crashes wtih RBR850 and 18Gb. Though maybe size was not large enough. I don't know. Seem that some of you are seeing this with larger sizes beyond 18Gb.
I supposed I can try removing CoD:MW from my xbox then have it re-install. I know thats a huge size now days.
Is this happening on both PC and game consoles?
- dwaxJul 19, 2021Guide
We dont have any game consoles. We have two different PCs that both can crash the router from battle.net (Call of Duty Cold war) or Epic(fortnite). Jsut last night oen fo the kids purchased a game (Sea of Thieves) from Steam and its download (40GB) crashed the router.
I did start playign with MTU size of the PC and it may have a small influence but it still crashed it Wired or WiFi
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
