dwax
Jul 14, 2021Guide
Orbi RBR850 crashes with large downloads
My kids and thier gaming require large downloads from battle.net and Epic games. These downloads are often greater than 100GB. When they start to download the router RBR850 loses its connection t...
- Aug 29, 2022
My Orbi 750 is running Firmware Version V4.6.8.2_2.1.9. Support suggested turning off Armor and that stopped the crashing. Awaiting a real resolution since paying for Armor but having to have it disabled for a game to download from Steam shouldn't be the solution.
Jul 22, 2021Guru - Experienced User
dwax You should have access to the beta version. Please let us know any results...
dwax wrote:Is there a phone number that I can call to get Netgear to try and reproduce this? Do they monitor this community?
Where or what files are you downloading when this happens? Is this a specific site or something on the game device?
I have two teenagers and from either of thier desktop PCs they can try upgrading Call of Duty Cold War done through battle.net
https://us.shop.battle.net/en-us/product/call-of-duty-black-ops-cold-war
Or Fortnite
https://www.epicgames.com/fortnite/en-US/download
the games are already installed on thier PCs and these upgrades from within the battle.net or EPIC software distribution systems.
Both boys PCs crashed the OBI router when either conencted through an RBS850 satellite OR directly wired into the ORBI RBR860
I did setup the LAN aggregation and I will see if that helps next time they need to upgrade.
I glanced at the /debug.htm screen and started looking at plyaing with capturign debug logs. Should I enable both?
Debug Log Capture
Start Debug Log Capture when boot up
Enable LAN/WAN Packet Capture
Since the main 112GB upgrade completed from the CM1200 I dont know how to try and reproduce such a large download. My boy no longer needs his software upgrade
Where is the beta kept? Is there an OPENWRT for this model yet?
dwax
Jul 22, 2021Guide
I have downloaded the firmware and I will try it Saturday when I have no meetings or conference calls.
I will let you know
- FURRYe38Jul 22, 2021Guru - Experienced User
:smileywink:
- dwaxJul 22, 2021Guide
I found some time inbetweeen my boys playing video games and company meetings and I upgraded the 3 satellites and the router. So far so good. I had one of my kids do what previously would have crashed the router and its running fine now.
thanks so much for your help.
Christian try to roll this out asap so you dont lose anyone. BTW are you on San Jose Plumeria? Im across the street!!
Good to hear. Thanks for letting us know.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dwax wrote:I found some time inbetweeen my boys playing video games and company meetings and I upgraded the 3 satellites and the router. So far so good. I had one of my kids do what previously would have crashed the router and its running fine now.
- dwaxJul 23, 2021Guide
Sorry flase alarm. It is still happening. Ill keep working on it and let you know. Ill probably use a different router and put the RBR in mesh wifi mode only
- Christian_RJul 23, 2021NETGEAR Employee Retired
Hi dwax,
Thanks for the update! May you send me a private message with the following info. I'd like for our support team to reach out to you for further investigation.
Email:
Phone:
Preferred Contact Time: (including time zone)
Router Serial Number:
Thanks,
Christian
- FURRYe38Jul 24, 2021Guru - Experienced User
Ok, So I'm checking on my 850 as well. I removed CoD MW (200Gb) from my xbox and it's re-downloading everything. I just started a 85Gb download of BF1 from Steam on my Windows 10x PC wired, as it's free to play this weekend. There both downloading thru the RBR850 with v223 loaded.
I'll report results after completion.
Well BF1 on PC installed just fine. No RBR problems so far.
- FURRYe38Aug 01, 2021Guru - Experienced User
So with the new FW it's still happening?
Did you factory reset the RBR and setup from scratch after v223 was loaded?
Is it only happening from these particular gaming sites?
Can you test something with a large download from a site, make like MS or Linux where you download something that large? Don't have to pay for anything, even a demo or trial SW.
Only other possibility would be that the RBR could be faulty.
Let us know how it works in AP Mode with downloading thru the RBR.
dwax wrote:Sorry flase alarm. It is still happening. Ill keep working on it and let you know. Ill probably use a different router and put the RBR in mesh wifi mode only
- dwaxAug 01, 2021Guide
I didn’t factory reset. Yeah it was still happening
I ended up giving up and bought a TPLink er605
Much better security.
Still had massive issues getting satelites paired in AP mode. I read all the forum posting on pairing in AP mode and eventually gave up with that, but got the satellites to work by just assigning static IPs to RBR and all RBSs and the disabling DHCP on RBR - dwaxAug 11, 2021Guide
Nobody ever reached out. I ended up buyin a new router. Perfectly stable now. There are also serious issues with getting the RBR in AP mode and then paring wiht the satellites with these pairing buttons.. I had to do it the old fashion way. Back to router mode issue there is definatley an issue in RBR. I have debug logs if you want them. NG will lose more customers than me if they dont get on top of it. If NG wants logs they can reach out
- FURRYe38Aug 11, 2021Guru - Experienced User
Did you get the beta FW from Christian?
I'll ask them to reach out to you.
FYI, I have my 8 series in AP Mode currently. Set up RBR first in router which was already running in router mode. Just changed the SSID name to something different, use same PW. Configured Static IP address for AP mode and applied. Connected the RBR to a NetDuma R1 router thats connected to a CAX80 in modem only mode. After RBR came online, turned on 1 RBS and let it auto sync on it's own as it had been previously synced with the prior SSID. I didn't have to press any buttons to re-sync it. It found the new SSID and connected. Same for 2nd RBS down stairs. Been online since:
Firmware Version: V3.2.18.223_1.4.15
CPU Load: 7.30%
Memory Usage(Used/Total): 438 MB/867 MB
System Uptime: 8 days 00:41:21
- jimhayesAug 17, 2021Aspirant
I have the same issue, when downloading from Google Takeout and large files. 50GB
I can cause the main router to kernel panic and it lights up red
Are other users seeing the red light when they have issues with large file transfers?
- FURRYe38Aug 17, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What exactly are you doing when this happens? Browser or app or device?
How are you determining this is a kernal panic? Debug logs?
I recommend you contact NG support and let them know what your seeing.
What Firmware version is currently loaded? v.3.2.18.1_1.4.14
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Netgear cable modem - details on the ISP don't matter to much, getting 1GB download, 50Meg uploadWhat exactly are you doing when this happens? Browser or app or device?
Safari download of Google Take Out data, 50GB files.
Debug log show zero, red lights on the main router
All network connectity is dead
What is the model# of the NG cable modem. Any information IS helpful for troubleshooting.
Does this happen when you use FireFox or Opera browser?
I'd recommend you contact NG support and let them know what your seeing. You can reference this thread as well. Ask about the beta that available for the 8 series system and see if this helps any. Possible that RMA maybe needed. Send them your debug logs as well.
- SQUIDWARD360Aug 24, 2021Guide
The issue with downloading updates from Battle.net and Epic Games store still exists. I've found that it is not only an issue with large downloads. Luckily, both launchers allow you to throttle your speed and keeping it at 10 MB/s seems to keep my router stable but obviously a tenth of the expected speed. So downloading games from Xbox or Playstation isn't really a true test of what is seen here.
I'm not interested in being a test case for fixing Netgear's products. They've made it so your equipment auto loads the next firmware but extremely difficult to ever roll it back when they've released terrible firmware.
- FURRYe38Aug 24, 2021Guru - Experienced User
You might try this:
What did your suppose case with NG result in?
- dwaxAug 24, 2021Guide
I used the throttling and decreased it from the max. It just delayed the router crashing by a little time
- jparrishNov 04, 2021Tutor
I have the same issues as stated.
For big game downloads on steam, battle.net, etc, my router goes purple and crashes. I just loaded up the newest Firmware.
I have an Orbi RBS750 (Costco version I believe) with 2 satellites running Firmware Version V4.6.5.14_2.0.54.
I have throttled to no avail, I've tried messing with advanced settings as well.
Any fixes discovered in the last 2-3 months?Thanks
- FURRYe38Nov 04, 2021Guru - Experienced User
Did you factory reset the RBR and setup from scratch after loading new FW?
What configuration are you using when downloading games? Wired or wireless? Game console or PC?
- jimhayesNov 04, 2021Aspirant
my solution was to get rid of Orbi 850 platform and move back to Eero 6 Pro's - much better experince, wifi performance was much higher (not expected) and the IOS app is rock solid.
Factory resets don't work, updating the same firmware does not help.
- dwaxNov 04, 2021Guide
I gave up on Netgear as the router. I use the ORBI for Wifi6 mesh but i ended up using a different router. I had no time for the minimal support
Yes. I did a factory reset and reloaded firmware.
I am on Fiber on a CAT6 cable straight into my house from the road which goes straight into my RBR. There's no modem.
It is a wired connection from the RBR. When I bypass the RBR with the singular fiber line, I have no issues.
This is all on PC.
