dwax
Jul 14, 2021Guide
Orbi RBR850 crashes with large downloads
My kids and thier gaming require large downloads from battle.net and Epic games. These downloads are often greater than 100GB. When they start to download the router RBR850 loses its connection t...
- Aug 29, 2022
My Orbi 750 is running Firmware Version V4.6.8.2_2.1.9. Support suggested turning off Armor and that stopped the crashing. Awaiting a real resolution since paying for Armor but having to have it disabled for a game to download from Steam shouldn't be the solution.
Dec 18, 2021Guru - Experienced User
Wanna try this?
When they start to download the router RBR850 loses its connection to the internt. This will occur at 5GHz, 2.4Gz or wired.
I have COX internet with Gigablast
When this occurs I can be logged into the CM1200 cable modem and see that it does not lose any internet conenction. My internet connection with COX is working fine.
Any ideas on what might be going on?
jimhayes
Dec 18, 2021Aspirant
The router has issues, and i was not able to correct with tech support. They wanted me to update the same ROM version and reset all settings but that does not work.
i hated to waste the $$ of the 3 node system that i purchased, ~$900 however i went back to Eero Pro 6 with 4 nodes, and i am getting the reliability and thruput
with my Orbi and my ipad next to the router i was never able to get more then 400mbs /sec, and my imac was not able to get more then 500mbs/sec
with the eero pro 6 in the same spot
i just ran speed test and my ipad resulted in 658mb/sec and my imac 868mb/sec
also, the eero ios app is way better
the Orbi did have better distance range outside..
