Jjersey63
Jan 14, 2021Apprentice
Orbi rbs750 app shows armor inactive
However, http site http://10.0.0.1/start.htm shows active - can't turn it off because app won't install it gives an error?
Christian_R
Jan 19, 2021NETGEAR Employee Retired
Hello Jjersey63,
May you provide a screenshot of the error when you attempt to install the Orbi app.
Christian
- Jjersey63Jan 21, 2021Apprentice
The app works fine, I think the issue is armor thinks I am active so on the app I can't activate because it's already active. I am not sure why the app thinks it's not installed. I can see on the armor site that it sees my router and appears to be active? So how do I get the app to activate if it's already active? I want the ability to turn on and off.
- Christian_RJan 25, 2021NETGEAR Employee Retired
Hi Jjesery63,
May you reinstall the Orbi app and let us know if your issue persists. If so, please provide me with your email address and serial number.
Christian
- Jjersey63Mar 05, 2021Apprentice
Ok well for some reason it's activated but I want to turn it off and it won't, if times out.
any ideas?
