Jjersey63
Jan 14, 2021Apprentice
Orbi rbs750 app shows armor inactive
However, http site http://10.0.0.1/start.htm shows active - can't turn it off because app won't install it gives an error?
Jjersey63
Jan 21, 2021Apprentice
The app works fine, I think the issue is armor thinks I am active so on the app I can't activate because it's already active. I am not sure why the app thinks it's not installed. I can see on the armor site that it sees my router and appears to be active? So how do I get the app to activate if it's already active? I want the ability to turn on and off.
Christian_R
Jan 25, 2021NETGEAR Employee Retired
Hi Jjesery63,
May you reinstall the Orbi app and let us know if your issue persists. If so, please provide me with your email address and serial number.
Christian
- Jjersey63Mar 05, 2021Apprentice
Ok well for some reason it's activated but I want to turn it off and it won't, if times out.
any ideas?
- Christian_RMar 05, 2021NETGEAR Employee Retired
Hi Jjersey63,
Please refer to the article below on how to disable Armor using the Orbi app. You may need to reinstall the Orbi app.
Christian
- Jjersey63Mar 10, 2021Apprentice
Yeah, it doesn't work - it times out. I've tried to reinstall but same result. Does something have to happen on the backend?
Christian_R wrote:Hi Jjersey63,
Christian
Christian
