CrazyEddie
Aug 08, 2021Apprentice
Orbi WiFi 6 and Control4 Vulnerability - No Details Available
I'm running an Orbi WiFi 6 mesh system (RBR 850 and two RBS850). I recently had some AV work done and a Control4 (EA-3) controller was added to the ethernet network. I've been getting alerts on the O...
Blanca_O
Aug 09, 2021NETGEAR Employee Retired
Hi CrazyEddie
Welcome to NETGEAR Community!
You can also view notification in the NETGEAR Armor portal https://armor.netgear.com
Here's a reference link: https://kb.netgear.com/000059454/
As for the Orbi app, may we please know the app version?
Blanca
Community Team
- CrazyEddieAug 10, 2021Apprentice
Hi Blanca - thanks for the welcome, and for the tip about the web portal. I was able to access the portal and found a bit more detail about the Control4 controller. The portal shows 9 "High risk vulnerabilities". I was able to drill down and see 9 apparently repetitive items listed as "Discovered product affected by a known public CVE", and then the following in a graphical presentation:
"Vulnerability description
Generic vulnerability. Don't worry, NETGEAR Armor will keep your device safe against hacking.
What should I do
What can happen
1 security risk(s)
- nginx 1.16.0"So I *think* that the top message of "Don't worry" is supposed to be the answer to the lower "What should I do"? Is there not a patch or something that I can get for the Control4 controller?My app version is 2.11.0.11
