GBIZ44
Jan 03, 2020Aspirant
Password issue
I've had this router a long time. I set it up with a long, complex password. Now when I try to access the router to set up a guest channel, the router login menu says my password is limited to 15 c...
GBIZ44
It's a N150 wireless WNR1000v3. I listed it below the subject, but it didn't "take" - probably too old. I was hoping to avoid the "reset" option, but it looks like I might not be able to.
Jan 03, 2020Guru - Experienced User
Wowsa!
Thats quite a bit older of a device and was very basic even when it was released 10 years ago.
Unless you're on some pretty slow dsl, an upgrade might show you some significant gains/performance improvement.
