radicalseven
Jan 15, 2020Follower
Printer printing out 3 sheets of gibberish
Every so often I check my printer (HP Color LaserJet) and it has 3 pages of gibberish. It says things like HEAD / HTTP 1.1 Host: IP address:9100 User-Agent : curl/7.59.0 Accept: */* There's ...
DexterJB
Jan 15, 2020NETGEAR Moderator
Hi radicalseven, welcome to the community! This has been reported to the engineering team and is being worked on. You can temporarily disable the Armor feature as other have reported that this as a workaround. The steps to do is linked below.
Dexter
- patelamApr 27, 2020Aspirant
Any update on a fix? This seems to be a very commonplace issue.
- Christian_RApr 29, 2020NETGEAR Employee Retired
Hello patelam,
May you let us know what firmware version your RBR20 is currently on.
Thanks,
Christian
- patelamMay 28, 2020Aspirant
- Christian_RJun 04, 2020NETGEAR Employee Retired
Hello radicalseven & patelam,
I'd like to follow up and ask if you were able to get the issue resolved. If not, may you please confirm the model number of your router along with the current firmware version its on.
Thanks,
Christian
