radicalseven
Jan 15, 2020Follower
Printer printing out 3 sheets of gibberish
Every so often I check my printer (HP Color LaserJet) and it has 3 pages of gibberish. It says things like HEAD / HTTP 1.1 Host: IP address:9100 User-Agent : curl/7.59.0 Accept: */* There's ...
DexterJB
Jan 15, 2020NETGEAR Moderator
Hi radicalseven, welcome to the community! This has been reported to the engineering team and is being worked on. You can temporarily disable the Armor feature as other have reported that this as a workaround. The steps to do is linked below.
Dexter
patelam
Apr 27, 2020Aspirant
Any update on a fix? This seems to be a very commonplace issue.
- Christian_RApr 29, 2020NETGEAR Employee Retired
Hello patelam,
May you let us know what firmware version your RBR20 is currently on.
Thanks,
Christian
- patelamMay 28, 2020Aspirant
- OxfordCrew20Aug 25, 2020AspirantRBS 20 satellite and RBR 20 router - printing 3 pages randomly every week - same three lines text
Head/ Http/1.1
Host: 198.168.1.2.9100
User-Agent: curl/7.59.0
Accept:*.*
That’s here in UK - spooky - just updated Orbi
Firmware V2.5.1.16
HP wireless printer- Christian_RAug 31, 2020NETGEAR Employee Retired
Hi OxfordCrew20,
May you factory reset your Orbi units and run through the setup assistant again.
Christian
- Christian_RJun 04, 2020NETGEAR Employee Retired
Hello radicalseven & patelam,
I'd like to follow up and ask if you were able to get the issue resolved. If not, may you please confirm the model number of your router along with the current firmware version its on.
Thanks,
Christian
