MMorgan707
May 10, 2024Aspirant
Question about Attack Warning
I received an "Attack" message from NETGEAR "Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on t...
May 10, 2024Guru - Experienced User
Just Armor letting you know that it's doing it's job.
Can do a Whois look up on that IP address to see where that is coming from if you like.
Otherwise, normal to get notices from Armor about items it blocks.
MMorgan707
Looking for an opinion on an "Attack" message I received: "NETGEAR Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on the this device for you. You're protected and don't need to do anything." I was concerned because it is an attack on a specific device and the message alerted 4 to 5 times and on different days.
Has anyone received this message or know if this is something to worry further about?
Thanks,
- FURRYe38May 13, 2024Guru - Experienced User
IP shows from this company:
inetnum: 188.240.13.0 - 188.240.13.255
netname: NL-DATAWEBGLOBALGROUP-20090623
country: NLhttps://datawebgroup.com
