MMorgan707
May 10, 2024Aspirant
Question about Attack Warning
I received an "Attack" message from NETGEAR "Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on t...
May 10, 2024Guru - Experienced User
Just Armor letting you know that it's doing it's job.
Can do a Whois look up on that IP address to see where that is coming from if you like.
Otherwise, normal to get notices from Armor about items it blocks.
- MMorgan707May 10, 2024Aspirant
Looking for an opinion on an "Attack" message I received: "NETGEAR Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on the this device for you. You're protected and don't need to do anything." I was concerned because it is an attack on a specific device and the message alerted 4 to 5 times and on different days.
Has anyone received this message or know if this is something to worry further about?
Thanks,
- FURRYe38May 13, 2024Guru - Experienced User
IP shows from this company:
inetnum: 188.240.13.0 - 188.240.13.255
netname: NL-DATAWEBGLOBALGROUP-20090623
country: NLhttps://datawebgroup.com
Do you think it is odd that it was tied to a specific device such as my phone?
- FURRYe38May 10, 2024Guru - Experienced User
No. Could be picked up on any or maybe some targeted attempt.
