MMorgan707
May 10, 2024Aspirant
Question about Attack Warning
I received an "Attack" message from NETGEAR "Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on t...
MMorgan707
Looking for an opinion on an "Attack" message I received: "NETGEAR Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on the this device for you. You're protected and don't need to do anything." I was concerned because it is an attack on a specific device and the message alerted 4 to 5 times and on different days.
Has anyone received this message or know if this is something to worry further about?
Thanks,
May 13, 2024Guru - Experienced User
IP shows from this company:
inetnum: 188.240.13.0 - 188.240.13.255
netname: NL-DATAWEBGLOBALGROUP-20090623
country: NL
https://datawebgroup.com
