MMorgan707
May 10, 2024Aspirant
Question about Attack Warning
I received an "Attack" message from NETGEAR "Armor detected that a suspicious remote location 188.240.13.2 attempted a connection to Pixel-7-Pro and blocked that connection. We will keep an eye on t...
BrianRubin
Jun 17, 2024Initiate
Hey, I'm having the same issue.
“NETGEAR Armor detected that a suspicious location 151.101.1.91 attempted a connection to [device here] and blocked that connection.”
It's always the same IP. The IP is owned by a company called Fastly, and they can't figure out what's going on.
Is there anything I can do or should be doing about this?
Thank you.
Topology
Jun 18, 2024Virtuoso
One resource that may be helpful when investigating suspicious IP addresses is the Abuse IP Database service.
- BrianRubinJun 19, 2024Initiate
Ah, so likely something not to worry about then. Okay, great. Thank you!
