captinboondoggl's avatar
Mar 18, 2020
R7900P Armor?
When I login to my router (web or all) the "armor" solution is displayed prominently but its unable to be activated.  The support page does not list this router as being supported.  Is support coming...
  • Christian_R's avatar
    Christian_R
    Mar 24, 2020
    Hello captinboondoggl,
    May you let us know if you're able to enable/disable remote management? May you also try reinstalling the Nighthawk app to see if there are any improvements.
    Thanks,
    Christian
