BruKat
Nov 25, 2020Aspirant
Random Printing
I have the some random printing with a Epson ET-2720 printer, usually once a week. Attached a sample printing, they are all the sam. I need it for remote printing. Need a fix, was told probabl...
- Nov 26, 2020
I thoguht I'd replied to this elsewhere, so appologies if this is a duplicate response...
The page you are seeing is being generated by Netgear Armor weekly scans.
The Netgear Armor / Bit Defender team will need to update their scanner. It appears currently they are sending scan commands to your printer to try to "hack it", but some of those commands are being sent over ports that are interpreted as "print" commands.
If your printer allows you to block IP addresses from printing, you could likely block any printing from 192.168.1.1. IF it doesn;t, then either it will need to be Off when the Armor scan occurs, or there will need to be an update to the Armor Scanner.
I know Netgear often updates the Bitdefender Armor scanner in newer firmwars...so make sure you are on the latest firmware for your router, as it may contain this fix. If not, I'd open a case w/ Netgear and even Bit Defender, they'll need to have their teams provide an update.
I see in your signature you have an R7000P router, are you on firmware: 1.3.2.126 ? Looks to have several fixes/updates related to armor, so worth a shot...You may need to factory reset your router after a firmware upgrade, and then reconfigure everthing...but I'd give it a shot without doing that first...
https://kb.netgear.com/000062478/R7000P-Firmware-Version-1-3-2-126
BruKat wrote:I have the some random printing with a Epson ET-2720 printer, usually once a week.
Need a fix, was told probably a Armor issue?
Have a paid Armor subscription also
Thanks
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
rinthos
Nov 26, 2020Luminary
Thanks
BruKat
Dec 02, 2020Aspirant
So far appears to be working
Thanks
