Christine67
Jul 05, 2022Aspirant
RAX35
Hello everyone, I am so frustrated this has been going on for 7 months now and I can't get any help!!! I surely hope someone in here knows how to fix this. How do I get my CELL SPOT from T-MOBILE to c...
Jul 05, 2022Guru - Experienced User
What cell spot is it?
have you put the cell spots IP address into the netgears DMZ?
Christine67
Cell Spot model SS2FII Femtocell multi-band SOHO.
That's the thing I have been trying to figure out how to do that, but can't seem to put 2 and 2 together. I'm an amateur at this but manage to figure most issues out EXCEPT THIS ONE!!!
Thank you for your help.
- plemansJul 06, 2022Guru - Experienced User
Does your router give the cellspot an ip address in its IP range?
If so, use that and put it into the dmz.
Otherwise try checking your access control list to see if it lists the cellspots ip address.
