MGogulapati
Jan 06, 2022Tutor
RAX48 "Advanced Config" page inaccessible on safari browser
     Upon upgrading to latest firmware "Firmware Version V1.0.5.106_2.0.70" on my RAX48 router, I am unable to access "Advanced " configuration of my router from my macbook using safari brower.  Upon ...
Jan 06, 2022Guru - Experienced User
does it work with other browsers?
Or a pc?
MGogulapati
Jan 06, 2022Tutor
1) I don't have any other browsers on my mac for addtional testing.
2) Yes, it works on windows pc, which I've included in my original post.
BTW, it is annoying to go to a different [windows] system to just to check or change "advanced" settings on the router.
- plemansJan 06, 2022Guru - Experienced UserI don't use safari so I"m not sure if theres a clear cookies/cache option. Have you tried installing a different browser to the mac and testing? It wouldn't be the first time a browser issue caused problems
