MGogulapati
Jan 06, 2022Tutor
RAX48 "Advanced Config" page inaccessible on safari browser
Upon upgrading to latest firmware "Firmware Version V1.0.5.106_2.0.70" on my RAX48 router, I am unable to access "Advanced " configuration of my router from my macbook using safari brower. Upon ...
amonynuts
Jan 12, 2022Apprentice
Same problem here on RAX45 with V1.0.5.106. Firefox doesn't work for me, under Linux. Safari & Chrome doesn't work either, tried these under iOS. Will try a firmware downgrade...
amonynuts
FYI, downgrading my RAX45 to firmware V1.0.4.100 resolved the issue for me.
- amonynutsJan 13, 2022Apprentice
Just FYI, to downgrade without the Advanced tab working, I was sent the following link by Netgear customer support and I was about to try this flashing method using a linux desktop using the "tftp" command: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
BUT, as soon as I connected my linux desktop to a wired port of the router and ran the latest version of Chome, as luck would have it I found that the Advanced tab actually worked using this browser version. So I just used the "Router Upgrade" option in the Advanced menu to install the older firmware from a file (instead of the convoluted method described at the URL above).
I also had to find the older firmware images on the Netgear website (will be in a different location depending on your router model).
Also I will note that once I got the router configured to my liking via the Advanced tab, I went ahead and upgraded to V1.0.5.106 again, just to make sure the latest security patches are installed.
