MGogulapati
Jan 06, 2022Tutor
RAX48 "Advanced Config" page inaccessible on safari browser
Upon upgrading to latest firmware "Firmware Version V1.0.5.106_2.0.70" on my RAX48 router, I am unable to access "Advanced " configuration of my router from my macbook using safari brower. Upon ...
G35flyer
Jan 20, 2022Star
I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
- chickenchickJan 20, 2022TutorThe workaround with error 404 and back doesn’t work
- MGogulapatiFeb 04, 2022Tutor
G35flyer you found a interesting workaround. Visiting non-exisitng page on the router, and clicking the browsers back button to to visit previous page, which would allow you to goto advanced setting.. Nicely done.
Thank you. It is helpful. - MG
- ExplorzFeb 15, 2022Tutor
Awesome. Worked for me.
G35flyer wrote:I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
- chickenchickFeb 15, 2022TutorWhat platform and which browser are you using??
My iPad doesn’t work this way with multiple browsers…- ExplorzFeb 16, 2022TutorMac. Safari
