MGogulapati
Jan 06, 2022Tutor
RAX48 "Advanced Config" page inaccessible on safari browser
Upon upgrading to latest firmware "Firmware Version V1.0.5.106_2.0.70" on my RAX48 router, I am unable to access "Advanced " configuration of my router from my macbook using safari brower. Upon ...
G35flyer
Jan 20, 2022Star
I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
Explorz
Feb 15, 2022Tutor
Awesome. Worked for me.
G35flyer wrote:I found a workaround. Once connected to the routers Basic web interface type any junk behind your rounter url....for example: https://192.168.1.1/junk You will get a 404 error, then hit the broswer back button and you can then gain access to the Advanced settings.
- chickenchickFeb 15, 2022TutorWhat platform and which browser are you using??
My iPad doesn’t work this way with multiple browsers…- ExplorzFeb 16, 2022TutorMac. Safari
