nateaf
Aug 12, 2019Follower
RBK50 Dropping internet with armor
When I enable Armor on the Orbi, internet will drop in 24 hours or less, and the only way to restore it is to reboot the router. With Armor disabled, I do not have any issues with the internet. I h...
Orbi-Roc
Oct 14, 2019Luminary
Hi nateaf . I was just going over some older unread posts and came across yours. I don't know if you were able to resolve your issue, but I will share my own experience with you if only for the benefit of other users perhaps. The dasy chain option is enabled by default on the Orbi router. If you only have one satellite, disabling it will get rid of the internet drops -- at least, this has been my experience. Once I installed a second satellite, I re-enabled the daisy chain option and that resulted in much better reach over the whole network, with no internet drops whatsoever. My Armor trial has since run out and I am still sitting on the fence as to whether or not I should buy the one-year subscription.
