dbrewood
Oct 08, 2021Guide
RBK53S - Armor is randomly blocking connections to Synology NAS
Since upgrading the operating system (DSM) on my Synology NAS from v6 to v7 Armor is randomly blocking outgoing / incoming connections to the NAS which means I can't access any systems hosted on the ...
Oct 08, 2021Guru - Experienced User
You could try going on and seeing if its blocking a certain site thats causing the issue.
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
- dbrewoodOct 08, 2021Guide
Alas no it's not - when the issue occurs it blocks all traffic internet from / to the NAS; http, https, VPN, remote connectivity, Maria DB, Apache, everything.
And before anyone asks all the corect port forwarding is in place. I've been running the Orbi / NAS pefectly for 8 months with no problems until I uplifted the NAS OS to the latest verison and then Armor decided to randomly block access.
- dbrewoodOct 10, 2021Guide
Anyone any further thoughts?
- plemansOct 10, 2021Guru - Experienced User
What firmware version are you on?
What modem/gateway are you connecting to?
- Boatman566Oct 15, 2021Aspirant
I have MS63 system and have the EXACT issues 3-10 times per day. ONLY when Armor is on.
Love to see the fix!!!
- dbrewoodOct 15, 2021Guide
Indeed, raise a ticket with Netgear Suport and tell them it is the same as my issue, ticket 45188388
