Les0515
Oct 15, 2022Aspirant
RBK752 Orbi WIFI6. What Armor software actually runs on the router?
microchip8
Oct 15, 2022Master
BitDefender
Les0515
Thank you for your quick response. If I understand your response than Netgear has a modified version of the Bit Defender software for their Router? If that is correct then I have to ask if it is possible for an end user to select which features of the software to run on the router or is it an all or nothing system? For example, I don't want any software loaded on to my home computers but just want software on the router that will protect my home network. I already have my home computers pretty well protected and am looking for something that provides additional protection at the router, before the internet traffic enters my network. Also I do not want the software to put anything from my network on the cloud since I believe that just increases the risk. That is the reason for my inquiry.
