iPalDK
Feb 27, 2023Aspirant
RBK852 - AX6000 with Amor enabled and Sagemcom Fast 3890V3 cable modem a Bad combination
After a very long process with my internet provider, I have finally solved my internet connection issues. Here is a brief story of the problem and how I "solved" it. Background: After repla...
Feb 28, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
Option #2 should have been tried to see if this would have helped with having Armor enabled in this configuration...
iPalDK
Feb 28, 2023Aspirant
Unfortunately, I can inform you that none of the proposed solutions work đȘ.
My cable modem is already running in bridge mode, and Wi-Fi is disabled. Therefore, I can exclude the double NAT issue and any Wi-Fi interference from my cable modem.
It's a bit frustrating that one has chosen a router based on the security software that came with it, only to realize that it is the piece of software that is causing the biggest problem on the network.
