thesamrohdeshow
Jan 30, 2023Tutor
RBR20 can’t renew Armor
Hi all Seen a few similar threads but no solution. My initial Armor trial expired and now I’m trying to renew subscription but when following the steps says Plan is not available. Any help with ...
- Jan 30, 2023
You should still be able to open a case for armor as its a paid subscription service.
https://www.netgear.com/support/product/netgear-armor.aspx
Jan 30, 2023Guru - Experienced User
Are you trying to do it through the app?
through a browser?
Did you try contacting customer service about it?
Or try a simple factory reset/reinstall?
